1 - 9 of 9 Posts
I want to verify something that I read in another thread.
If I run just the Jetta headlights and grill, will the Golf hood still function properly without modification and give a slight boser effect?
Thanks in advance for the info.
Re: Jetta lights / grill on a GTI...? (Spd33)
yeah the golf hood will still function properly... if you consider flying back into the windsheild of your car (kinda tommy-boy style) proper function. you have to change the hood if you change the lights and the grille...no way around it http://****************.com/smile/emthdown.gif
unless of course you wanna do lots of modification to it...
[Modified by pdxvento, 9:36 PM 11-29-2001]
Re: Jetta lights / grill on a GTI...? (pdxvento)
quote:[HR][/HR]yeah the golf hood will still function properly... if you consider flying back into the windsheild of your car (kinda tommy-boy style) proper function. you have to change the hood if you change the lights and the grille...no way around it http://****************.com/smile/emthdown.gif
[Modified by pdxvento, 9:36 PM 11-29-2001][HR][/HR]​
Are you positive? I can't see how other than looking different that changing the lights and grill would cause what you describe.
[Modified by Spd33, 9:39 PM 11-29-2001]
Re: Jetta lights / grill on a GTI...? (Golf_CL)
quote:[HR][/HR]Well if Stealth is using a Jetta hood with dual rounds and gti grille then you should be able to do the opposite.[HR][/HR]​
That's what I'm thinking. Just want to verify it. - Andy
Premium Member
That's what I'm thinking. Just want to verify it. - Andy[HR][/HR]​
Except he has a gap right now. The Golf hood will damage the Jetta lights. There is not enough clearance without modifications.
1 - 9 of 9 Posts
