Does anybody have a Jetta S and would like some info on a cruise control install? I just added cruise control to my Jetta S with oem parts and I still have the part numbers along with wiring diagram info and coding info.
I don't know what diagram you have but the cruise switch is on the end of the turn signal stalk just like a Jetta SE or SEL would have. The part I put on is for a 2013 Jetta S with sunroof which comes from the factory with cruise.I have seen photos of the turn signal stalk with CC on it, but the VW diagrams show a separate (3rd) stalk that appears to be located below the turn signal. Which is it?
Did you (or could you) take any pictures during the process?
Obviuosly not.Did none of you see my thread?
I just installed cruise on my boss's 2011 Jetta S with the same part numbers my 2013 used so it's probably safe to say your 2012 would use the same part numbers.I just picked up a 2012 Jetta S and am already missing cruise just a couple days in. Are those part numbers the same for the 2012 model?
Use this, it is very helpful :beer::thumbup:Did none of you see my thread?
where are you located?How do you find out what part number your BCM is? I don't want to buy the parts if it's not even possible to do... but I can't figure out where the BCM is to see if it's even possible.
Thanks
