Quote, originally posted by threethirteen » |
shoulda just rented the tool...it takes about fifteen minutes/side... |
Quote, originally posted by Live-Wire » |
Why rent. I bought a universal brake caliper cube for 15 bucks... had to grind off some "extra" prongs on it to make it work, to fit in the two holes that Audi uses (the correct spacing on my cube had a 4 hole pattern, so I took off two corners)... Put it on a 3/8" drive and screwed it down by hand... rear brakes are easier then the fronts IMO. |
and now you can only use it your car. buy the kit for $30 and it works with all cars...and you dont waste time grinding off the prongs. and as for renting...renting is FREE ![]() |
Quote, originally posted by nidnabd » |
Nonetheless, it was gravy. Need a write up here, so other people dont have to search AW or Audizine for the info they need.
Quote, originally posted by robbyb413 » |
You need to search to know how to change your brakes? What is this your first car? Regardless, this needs no write up. You can ask Robert Bentley, he'll tell you all you need to know. |
No, people are effing lazy. Read your god damn Bentley, thats what their for. DIYs and Walk throughs are super for things that arn't in the bently or are hard to find in the shop guide. For instance, following wiring diagrams, well, I could understand why someone would post for that, because it's a PITA to follow some of them sometimes and you just need the answer right away. But for a brake job? Come on. Get serious. The Bentley has a walk through right in there. It's not complex, but if you absolutely NEED to have someone show you how to do it, hop on there. As a matter of fact, without the Bentley where are you going to get your torque specs? So it's not even worth doing it without one. |
Quote, originally posted by zaxonortesus » |
nibnabdI'll be heading up your way around Aug I think, well, to Grand Haven, but I might hit you up to see if there are any GTGs goin' on |
