Re: Just found a problem... (JoeHydrickGTI)
Sounds like a bad wheel bearing or lower ball joint. Would also check the steering tie rod ends. The strut to hub carrier bolts should be torqued to 58 ft-lbs. I would not drive the car until the problem is resolved. Good luck, WWR.
