1 - 6 of 6 Posts
Re: Just got a ross tech... Need some help figuring out (BostonGTI)
Well there used to be a really good post here by Wolfsburg2 but it looks to have been deleted. Maybe he will chime in with a copy.... Anybody else save that post?
Re: Just got a ross tech... Need some help figuring out (UKAUSSI)
Really rough mbar to psi boost calculation
((mbar - 1000) * .0145) = psi
The -1000 is to try to compensate for atmospheric pressure. Without it you will think you are running up to and over 25psi
. 1000 mbar = 1 bar = 1 atmosphere at sea level. If you want an ACCURATE measurement you will need a barometer on the outside of your vehicle to measure actual atmospheric pressure.
Re: Just got a ross tech... Need some help figuring out (Crass!)
Make sure to log a single measuring block at a time because more blocks will give you less "resolution" so to say - It'll lower your sampling rate per block...
Re: Just got a ross tech... Need some help figuring out (Gambit)
quote:[HR][/HR]Make sure to log a single measuring block at a time because more blocks will give you less "resolution" so to say - It'll lower your sampling rate per block...[HR][/HR]​
i agree,when i do 1 block i get roughly 42 measurements but when i log 2 blocks i only get maybe 20
1 - 6 of 6 Posts
