1 - 20 of 25 Posts
i just installed a new clutch (including the flywheel) about 3 days ago and it was working great and now today it started to slip......could it just be that i have to re-adjust the clutch cable or is it something else. if it is just the clutch cable i cant seem how to adjust it....i have been told i have a self adjusting cable.
Re: just got done installing my new clutch (justforfun)
get rid of that self adjusting cable . it will ruine your clutch.
get a regular one and adjust it
The mkiii's came with a self adjusting clutch cable, which will definitely lessen the life of the clutch. How much, not exactly sure. But, it's nothing major. You can swap it out with a manually adjustable unit, which will give you the option to fine tune the set-up.
Now, in regards to your clutch slipping, did you do the work yourself? Did you let the new clutch break-in? Did you follow the recommended fluid levels?
Discussion Starter · #4 ·
Re: just got done installing my new clutch (ramylson)
ok the clutch has been in for about a week now and it still slips...so i dont konw hwo long to let it brake-in...and as far as the fluid..the book i got told me that the clutch fluid is the same as the brake fluid and i dont know if have to blead the clutch just like the brakes and if so how
Quote, originally posted by justforfun »
Let me get this straight.. when you did the work, you put brake fluid in as clutch fluid?
If Im not mistaking, the 2.0 Has a cable clutch. Not a hydro. There should be no fluid at all.
Nate
Discussion Starter · #8 ·
no dont have a hydro clutch so i was getting confussed..i read the cheltons and it said that the clutch fluid ran with the brake fluid....but since it is a 2.0 its "100% cable
thanks guys for all your help....the car is running fine..but when i turn the car off after driving the clutch has that smell of it sliping
Re: (justforfun)
is it sliping or does it smell like its slipping. BIG diff. smell means its prob braking in. Slipping means somthing more.
Nate
Re: (Nat1267)
this is the first I've heard of a self-adjusting cable causing rapid clutch wear.
I had 120,000 miles on my old clutch, and it still had a LOT of meat left.
Discussion Starter · #11 ·
Re: (Nat1267)
it just smells like it is slipping....but when i take off from a stop the shutters and shakes like crazy, just like i am not giving it enogh gas
Modified by justforfun at 3:06 AM 5-26-2004
Re: (justforfun)
did you:
1) get any oil, grease, or otherwise on the fiber disk?
2) Clean the metal disk with brake cleaner?
Discussion Starter · #13 ·
Re: (Pagano)
you know i did buy brake cleanner and everything but i was to excited that i was almost done that i didn't spray and cleaner on the disks
...but i dont think there was a lot of grease on the plates
Re: (justforfun)
Hate to say it but it dont take alot.
Nate
Discussion Starter · #15 ·
so are you saying i have to take the tranny off again and spray the flywheel with the brake cleaner....man i hate myself right now
Re: (justforfun)
LOL its all good dude, there has been worse done, To answer your question, I dont know. Hopefully one of these other guys might know the answer. Sorry I cant help ya out there. To be honest. The only prob that you can fix with out taking the tranny off is replacing the clutch cable with a non self adjusting unit. It soulds like most anyother fixe is gona mean removing the tranny.
Nate
Re: (Nat1267)
Nat, how difficult is it for a home DIY to replace the clutch .... my 4th & 5th gears are already slipping so I'm not to far away from a change (upgrading though to a 16V pp & lightened flywheel). I really want to try it myself but don't want to f-up my car completely in the process. Any suggestions?
Re: (justforfun)
did you put a lightened flywheel in? that could be why it shakes... i'd hope you would know that though if you did the job yourself
. also, did you replace your rear main crank seal, trans input shaft seal, and throw-out rod seal? cause if either one of those leak they'd spill oil right onto the disc/flywheel/pp. good luck figuring it out!
kyle
Discussion Starter · #20 ·
Re: (availrva)
Quote, originally posted by availrva »
kyle
thanks man for all the informantion but everything just worked itself out....kind-of like the self adjusting clutch..
1 - 20 of 25 Posts
