OK I went ahead and ordered Windows 7 64 bit to install on my MBP via bootcamp. I will report back if there is any trouble running VCDS but based on this I don't expect any:
1.16 What about Windows 7?
Yes, the current VCDS Release version fully supports Windows 7 (both 32 and 64 bit versions) .
Everything stated in the previous two questions about Windows Vista also applies to Windows 7. However, there is one caveat:
- If you have a genuine Ross-Tech interface which is compatible with current VCDS versions,
you should use the latest Release. We introduced a Windows-7 aware installer starting with Beta 904.
