Well its been a long time between drinks for my Mk1 or even posting on vortex.
Alot has been happening over the years, but I'll just focus on the Mk1. Yes its still going!
Last time I raced it, was April 2011!!
After hearing about a big group of mk1 numbers at a recent VW drag event in QLD Australia, I figured it was time to maybe have another crack with it.
So back in went the Spec drag clutch & the locked diff. diesel 4spd box.
I also fitted a new spherical shifter base for a more positive shift, as the original one was still fitted from 1976. The stock one wasn't sloppy, just time for an upgrade.
I also fitted some new front control arm bushes. When I first built this 76'er, I upgraded to 1979 arms with the larger balljoints & they still had the original bushes fitted from new.
They weren't stuffed, but when you'd launch the car, the front wheel's would pull forward causing the alignment to pull into toe-out & the car would wander through the first 60ft.
The new bushes are stiffer & noisy, but reduced the wheels movement on the launch.
Another thing was to get some new tyres, as the original Toyo RA1'a I use to use are shot & hard.
There are not many motorsport/drag tyres out there that are a street radial, 205 wide max & only 22" tall
So I was left with very few options. So on went some new Toyo R888. on some stock mk1 13" widened rims to 6".
After all the bits were fitted it, a service (as it was just over 10K since its last one), new gapped plugs etc., it was onto getting the tune dialed back in.
After a few power runs I felt the mixtures, boost & timing were good & safe & the car felt strong pulling hard 2-4th..
So packed my stuff & waited for the next day.
First thing, got everything ready, threw in some Nulon octane booster as a safety barrier if I decided to put a few more degrees of timing in it & headed off to race it.
Half way into the trip I noticed the car felt very sluggish & didn't rev freely to its 7000 limit.
The mixtures were alittle bit over the place & rechecked the ignition timing at the track. It hadn't moved & was all good.
As its my daily driver (not weekend car! Its my only car at the moment), I had to be careful how I launched it, as I also had to drive it home.
I'm also entered in the 5 day/4 track Drag Week type event here in OZ in a couple of weeks.
So not only do I want test it out after all this time, also try & run some good numbers with it, but also have to be careful not to break it.
First run, no issues heating the tyres in 2nd gear. Staged, 2-step, build boost & launched gingerly & it struggled to rev & barely made anywhere near its boost limit! WTF!
[email protected] 2.3 60ft. I was confused!
Came back & looked over everything. Everything was good. Timing was good, mixtures were all over the place though.
Screwed the boost controller up alittle bit & had another crack.
Boost still didn't want to come up, struggled to rev &
[email protected] I thought this is crap! It was heaps better yesterday.
So I decided to start pulling fuel out of the tune to lean it off a bit.
Next run
[email protected] 2.0 60ft. Still crap & its best for the night!
This was basically how the night went on. Pulling more & more fuel out of it till it was lean & didn't make any difference! I was confused.
It was down 3mph from its best.
I thought, I know the K-jet is a very finicky & temperament system to different brands of fuels & thought maybe the octane booster has played funny buggers with it.
The tank was nearly empty after the runs, & filled up with fresh BP Ultimate. Its 1.5hr trip each way to the track. Half way home with the fresh fuel, it started picking up grunt again & had no issues building boost or revving to its limit! By the time I got home, it was turning the sticky tyres from a 60km roll-on without issue!
So I put the night down to a learning experience in regards to octane boost & K-jet, as I'd never tried it before & it failed.
But it was still good to get out racing after all these years & have a crack at it again
Also to test it before drag challenge & also be able to do a 3hr round trip, race it & not break anything.
& if anyone has experience racing early fwd VW's, its like trying to hammer a nail in with a glass hammer! You can't be violent with these drivetrains.
Was also surprised at the attention the rust bucket received too.
All positive & were very surprised. Especially when you say its a stock early 1.8L, journal bearing turbo & mechanical injection (which 99% of people didn't even know there was such a thing!) & it has gone faster.
I would of like to at least run low 13's at least after a long hiatus , but it wasn't meant to be tonight.
So will put another tank of fuel through, put all the tune settings back to how they were originally (I checked, marked & wrote down everything before playing around with the tune) & start again & have another shot in a couple of weeks.
I can't guarantee any times, but I'd like to make it through the week with a low 13's average, but the ultimate would be to see a 12 again after a 4+ year rest from racing.
