technically speaking the precedure is basically the same as immo 3. except for the fact that the transponder must be precoded. the key that i am trying to code to the system is a original key cut from vw using the vin nr.etc. according to the guys down here from the factory, a key ordered from vw comes precoded to the vin in the vehicles cluster. i have tried coding the key using vag com. the cluster excepts the skc, adaption. 01, new amount of key, save. exit. but the SAFE symbol on the cluster does not want to dissapear. what i have noticed in the beginning when i have punched in the skc, the SAFE symbol were flashing. after a few attempts the SAFE kept staying on when i have made a attempt to code the key. please try and assist. is it possible for other faults in the ecu to affect the coding of keys to immo. having no problems communicating with ecu and cluster. see immo log. thanks.
Saturday,17,April,2010,14:15:42:36545
VCDS Version: Release 908.1
Data version: 20091018
14:15:16
No Engine Start permitted
Yes Engine (ECU) responds
Yes Key Status OK
2.0 Number of adapted Keys
Yes Variable Code authorized
Yes Key Status (Transponder Lock)
No Fixed Code authorized
6.0 Immobilizer Status
0.0 Login-Lock Tester
0.0 Login-Lock CAN-Bus
0.0 Lock Scan Protection
0.0 Status Immo-LED
Saturday,17,April,2010,14:16:39:36545
14:16:29
No Brand (Key) Recognition
N/A Engine Start permitted
N/A Engine (ECU) responds
N/A Key Status OK
N/A Number of adapted Keys
N/A Variable Code authorized
N/A Key Status (Transponder Lock)
N/A Fixed Code authorized
N/A Immobilizer Status
