1 - 20 of 21 Posts
Discussion Starter #1
well i go to the beige harness under the steering wheel. when i found the clear wire (antenna) it was spliced with a black wire about 2 inches up the wire
. i dont want to splice anything yet because in the DIY there was no info about this black wire. if i splice should i splice above where they are connected or should i just disregard the black wire and splice below where they join.
pics (clear wire is labeled in red and black is labeled in black.
Discussion Starter #3
bump...do u think it would be okay to cut above the splice?
or should i cut right below (clear wire) and then add my antenna cable.
Modified by will665 at 11:34 AM 7-6-2006
Discussion Starter #5
Re: (bootymac)
Quote, originally posted by bootymac »
Hi, I wrote that DIY guide. Just cut below the splice and you should be fine.
k cool...does that black wire just become worthless or something...just curious
Re: (will665)
Quote, originally posted by will665 »
I never found out what it's for, but I didn't want to screw around so I left it alone.
Discussion Starter #9
Re: (Ikaika)
Quote, originally posted by Ikaika »
what he said. Have fun attaching the wire, the original is about as thick as a hair.
dude...they call me the master splicer because i once spliced a split end to a non split end
Re: key fob extension diy problem (will665)
Its hard to tell from your picture, but I'd guess the antenna wire is coaxial to the splice, and the black wire is shield ground.
Discussion Starter #11
Re: key fob extension diy problem (John and the GTi)
Quote, originally posted by John and the GTi »
makes sense http://****************.com/smile/emthup.gif
Discussion Starter #12
just finished this mod. when i cut off the antenna that runs thru the pillars i put electrical tape at the end. do u think i should keep it without the tape or with. (does it have an effect on signal strength) otherwise this mod is sweet http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
when i did this i just used one of those 3m wire taps so now i have the original antenna as well as the 8 foot extension.
edit:
<--- i'm so high right now
j/k
Discussion Starter #15
Re: key fob extension diy problem (DubsMcGee)
Quote, originally posted by DubsMcGee »
edit:
j/k
420!!!!
there is a really really good DIY out there in the Vortex... dunno if hte pics are still up
Discussion Starter #17
i am finished. it incresed the range to 140ft. and the battery in the remote is almost dead.
Re: (will665)
nice job! my battery is brand new, but for some reason i have to be RIGHT next to the car for it to work
Re: (mujjuman)
Quote, originally posted by mujjuman »
stick it under your chin, human antenna is good for another 10 feet
1 - 20 of 21 Posts
