Re: Key gets stuck in the ignition and sometime takes force to start: 2002 Passat (dankatz)
quote:[HR][/HR]Try jiggling the wheel.[HR][/HR]
The steering-wheel lock is engaging, probably because you turned the wheel
after removing the key. Just turn the wheel a little and the key should turn easily, then try not to use the steering wheek as a grab handle when you get out of the car
