Sachs Billet Steel Flywheel, 14 lbs. (G60)
This is a great opportunity for you guys. We have a limited number of Sachs lightweight single mass flywheels in stock, ready to ship. Scaled at 14lbs, these G60 flywheels are perfect compromise between the heavy stock weight SMFs and lightweight SMFs rated at 7/9/10lbs which in general cause chatter. We all know Sachs is THE German OEM Supplier for VW and Audis so the quality is there.
These G60 flywheel kits, mated with VR6 clutch kits (228) will be a solid upgrade for all MK4s and New Beetles with a cylinders.
This kit comes with flywheel bolts and clutch pressure plate bolts.
(Click image for more information or to order)
