Hi-
I just installed Koni Sports and H&R springs on my 93 VR6 and it looks GREAT!
Problem: It rides AWFUL. I have had (and still own) lots of cars that are lowered... in fact, the 58, the 65 and the 01 are all lowered. None of them ride like this. The fronts are on Full soft, but I don't know where to adjust the rears... any suggestions? Do I have to take them back out, push down, then rotate the shafts counter-clockwise? That's what Ive heard, but no soild info...
Is it simply because these are Koni Sports?
Should I set them soft or so you think that maybe they need to be set harder than they are? The car does not bounce over bumps, it feels like there's NO suspension-- like a gokart. I can't tell if the springs are overpowering the shocks or viceversa.
Also,
I installed Mintax Red boxes with ATE Power rotors (stock ATE for rear).
I didn't open the system at all, but the pedal is very mushy now. The pedal was firm before I did this. I suppose they need to be blead, and I should probably flush the fluid while I'm at it.
Any other causes for a mushy pedal? This is the first ABS I've done brakes on... Could that be related?
Thanks!
Also,
Thanks!
