Thanks again
@Jules_r and
@ZERO815 for the detailed instructions and help! I got the BCM out with some fiddling and sliding myself under the dash looking up into it. I did end up taking it out as it was easy enough to get it out once the plugs are taken out.
looks like I have both pins B5 and B6 and I am pretty sure the 2019 NA beetle cabrio S has multi link rear suspension (see picture) but it doesn’t matter since we don’t care about auto leveling now
It's not very easy getting your head in there and looking up, but once you have done it once it's quite easy, just fiddly.
Great that you have the all important pins. Well done!
ECS tuning has the lights
left - 5C1 941 031 H
Genuine replacement HID headlight assembly with LED DRL's
www.ecstuning.com
right - 5C1 941 032 H
www.ecstuning.com
Few follow up questions..
- part numbers are slightly different (H vs D) - are these auto leveling ones and I want the manual leveling ones?
No, D are manual leveling so H is likely just a supersession.
A quick Google found this website..... and it states that H replaces D, cheaper, too!
Save Big On This OEM VW Headlamp Assembly, Part #5C1-941-031-H for 2014-2019 Volkswagen Beetle. Wholesale Prices, Fast Shipping, Order Online or Call 888-667-8938.
www.vwpartsvortex.com
There is a system on that site where you can check if it's right for you, you need to be 100% sure!
- anyone know if these lights for $2800 a pair come complete with the ballasts, bulbs or are those separate?
I think generally Xenons do come complete with ballasts and bulbs. The picture on that link ^^^ shows them, and mine, which came direct from the manufacturer (Hella) came complete. Mine were even adjusted correctly.
- is the adapter from Kufatec just a pigtail on the existing halogen harness or do I need to run wires back to the BCM plug B for pins 5 and 6?
You do have to run a thin cable (2 wires) from the headlamps to the BCM so it has to go through the bulkhead, that was the bit that worried me most, but it's no big deal, really nothing to worry about.
The wires to the BCM have pins already attached. All you do is push them into that big plug. As long as you get them in the right holes your sorted!
- last.. if I plug everything in and don’t reprogram do the lights come on without the hi-lo flasher working?
I'm not familier with US spec cars, but I'm pretty sure the lights work slightly different so I'm not sure what would, and what wouldn't, work.
@ZERO815 would probably know the difference USA vs. Euro
There were 4 or 5 things (Bytes) that needed to be re coded on mine. I didn't try Hi/Low until it was coded so not sure about them but I do know the DRL's didn't work until the coding was right.
If you are going to do it you have to code it right. OBDEleven is cheap and works great for this kind of thing.
When I did mine the coding supplied by Kufatec was wrong. The DRL's are super bright, they obviously need to be because they are for day time. When you switch to side lights (not sure if you have them, or maybe you call them something different) the DRL's should dim..... if they didn't they would be way too bright at night.
That was the problem with the Kufatec coding..... they didn't dim as they should so anyone out there with Kufatec coding will be dazzling other drivers when it gets dark. I worked out how to fix it and Kufatec did amend their manual.
