KW V2 Coilover suspension (Non-DCC) Used for 3000 only miles :
$1500.00 FIRM, Low Ballers WBI.
Local pick up preferred - Boston Area, if shipped I will pack it in a secondary box - buyer pays shipping.
*See bigger pictures below.
These coil overs are adjustable for street and track and ride better than OEM while able to go really low. Comes with fairly new bearings as well (Also 3000 miles).
The strut mount tabs have been altered to run more camber and avoid contacting the inner wheel well. There are some areas where the paint chipped on the springs, they are minor and have little to no surface rust where it has happened and could be touched up fairly easily. These were NOT run in winter. They have not seen salt and very little water.
You will need adjustable Swaybar End-Links with these.
They come with rear lift disks in case you want the back higher.
Other Parts I have for sale that pair with this setup:
• Superpro Strut Mounts with negative 1.4 degrees camber, Brand New, : $260
• Superpro Adjustable Sway-Bar End Links : $100
SOLD : Eurosport Negative camber strut mounts based on the OEM strut mounts for less NVH : $280.
