Re: Lambda>voltage calculator? (MarcoVW)
are you talking about the signal from the O2 sensor? are you using a multi-meter instead of a dwell meter and need to do the conversion??
the scirocco.org tech page has a chart showing voltage->A/F ratio based on the signal from the O2 sensor... is that what you need?
very early in the morning here, more coffee needed....
