1 - 8 of 8 Posts
I'm aware that the JH engine came with a larger air flow sensor than the EN-EH engines in the MK1 sciroccos. However, these engines were CIS-Lambda, and mine is not. Was there ever a larger air flow sensor/fuel dist. that did not have a frequency valve?
What are the actual sizes anyways?
Marc
81 'rocco S
[Modified by Norm95, 11:23 AM 12-1-2001]
Re: Larger air flow sensor? (vwpat)
Really!?
Great...I get the engine with the small one...
Got a old school engine tuning project well under way...
Marc
[Modified by Norm95, 12:06 PM 12-1-2001]
Re: Larger air flow sensor? (ABA Scirocco)
I have an 81 Roc' and it has 80mm, in fact I have yet to own or see a car with a 60mm housing. Look at the list below, 2 EN's and 2 EF's I think and the 1.7 is FN? Don't know about you guys down there though.
James.
[Modified by A1Rocco, 11:53 PM 12-1-2001]
quote:[HR][/HR]1.5, 1.6 and 1.8 used 80mm. 1.7 used 60mm. You can use either with or without lambda.
At least some 1.7's came with 80mm, my 83 Scirocco did.[HR][/HR]​
83 rocco should have a 1.8 and therefore 80mm sensor.
Re: Larger air flow sensor? (A1Rocco)
quote:[HR][/HR]I have an 81 Roc' and it has 80mm, in fact I have yet to own or see a car with a 60mm housing. Look at the list below, 2 EN's and 2 EF's I think and the 1.7 is FN? Don't know about you guys down there though.
James.
[Modified by A1Rocco, 11:53 PM 12-1-2001][HR][/HR]​
Maybe it was US only.
1 - 8 of 8 Posts
