Lay flat rear wiper... how?
972 Views 18 Replies 11 Participants Last post by  The_Hamster
I'm sure this will have been covered before, apologies!
How do you get the rear wiper to lay flat along the bottom edge of the screen?
Ta!
Jez
See less See more
1 - 19 of 19 Posts
Re: Lay flat rear wiper... how? (Jez)
Look here young Jedi.
Re: Lay flat rear wiper... how? (Ankh)
Thank you kindly, sir!
Jez
See less See more
4
Thanks from me too. http://****************.com/smile/emthup.gif
See less See more
Re: Lay flat rear wiper... how? (retrohasen)
my ex's golf thanks you too. http://****************.com/smile/emthup.gif
See less See more
Re: Lay flat rear wiper... how? (rockin16v)
first mod i did when i got it 2 years back
was there a reason why VW did this the way they did??
See less See more
Re: Lay flat rear wiper... how? (Dutchman)
Yep, after a LOT of wind tunnel testing they found that parking the wiper at an angle was more aerodynamic than parking it flat. They only sorted out the aerodynamic problem with the Golf III!!! Apparently if you have a spoiler fitted to your Golf I or II it helps though.
See less See more
Re: Lay flat rear wiper... how? (VW-DOHC-16V)
a brick has aerodynamics when you put a wiper on it
See less See more
3
I did this but still cant get the wiper to lay completely flat. It hits the washer nozzle. In all the pictures I see the arm is completely flat.
Re: Lay flat rear wiper... how? (robgti)
just bend the wiperarm a little and then lay it flat
mine touches the washer nozzle
but it doesn't hit it when sweeping
Well I'm no expert on aerodynamics, but wind resistance isn't lowered by just having an aerodynamic front end, because the air fills the area immediately behind the car after the car has passed, so basically you have to make your car's rear reasonably smooth, and VW found that by parking the wiper at an angle, the air passed over the car easier!!
And the Golf II isn't a brick, it's drag coefficient is .32, the sdame as an Audi TT!!!
See less See more
Re: Lay flat rear wiper... how? (Juicejetta3)
juice.. don't push it
really??? same as TT
you wouldn't say so when you look at them (or drive it)
Nope, you wouldn't really, would you?
Those TTs don't look half as fast and sleek as the classic that is the Golf II
See less See more
quote:[HR][/HR]Dont push what? rear wipers are for minivans and Honduhs (rice, for the common person)[HR][/HR]​
my golf came with one
and "mr honduh" gave me some good information, which i'm very thankfull for.
it shows he knows his stuff....
so cool it Mr. 3%
[Modified by Dutchman, 12:45 AM 12-1-2001]
See less See more
quote:[HR][/HR]VW found that by parking the wiper at an angle, the air passed over the car easier!! [HR][/HR]​
Wow! That's really arcane ! How the hell didja discover that? It still seems a bit far fetched, but then again, I'm no aerodynamicist!
quote:[HR][/HR]And the Golf II isn't a brick, its drag coefficient is .32
[HR][/HR]​
Now this one I'm embarrassed to admit I didn't know after being an A2 owner for many years. I guess since I thought it was higher, I wasn't motivated to really know !
See less See more
4
Re: Lay flat rear wiper... how? (niels_dale)
To use the eternal phrase that springs to mind when someone asks how I heard something "uhh, I think I read it somewhere..."
It's actually due to it's more aerdynamic styling that the early model 8V Golf II GTI is (albeit marginally) faster than the similarly engined (and substantially lighter) Golf I.
Thus I have just now exhausted my entire knowledge of anything to do with VW ever
See less See more
2
I took my rear wiper right out , I never use it. Took out the motor , wiper arm and used a gromet to cover up the hole.....I think it looks ok too , never did like it anyways
See less See more
quote:[HR][/HR]a brick has aerodynamics when you put a wiper on it
[HR][/HR]​
lol
i didn't know the it had the same cx as the tt, actually never thought of the cx of a mk2, thought it would be through the roof
See less See more
4
Re: Lay flat rear wiper... how? (mk2jetta)
IF i had a golf, i would take it out totally, but that's just me.
1 - 19 of 19 Posts
