1 - 7 of 7 Posts
I installed LED headlights and fog lights in my 03 beetle and a week later the passenger side low beam stopped working. I'm not sure what I did but I got it working again but then my fog lights weren't working but my low beam was. I messed around some more and my fog lights worked but my low beam wasn't again! HELP!!
Orig owner 90 g60, 02 allroad 6SP M w/ 3rd Row, 07 3X White NB Vert, 09 Escalade ESV Plat to tow em
Undo what you installed and see if matters resolve themselves.
Sent from my iPhone using Tapatalk Pro
2021 HiHy Platinum AWD
Did you disable the DRL's at the headlight switch?
There may be many reasons why LED light works and low beam does not. You may have a problem with the wiring. If you connected the LED car lights yourself, then you could touch the wiring from the low beam, and thus the contacts could move away, and because of this, you have problems with the light. It is also possible that you just have a defective LED light or low beam, and because of this, again, you have problems with the light in the car. In any case, it is very difficult to determine what happened to you, so it is better to contact specialists who will check the wiring of your headlights.
1 - 7 of 7 Posts
