Hey! I've been reading through and have come to find that a lot of people actually have lifted their mk1's for one reason or another. I was hoping to compile a bunch of information from different threads to help myself and others in the future to find information. Here is what I have so far:
-Stock suspension with strut spacers and flipped drop brackets: seems to be popular with caddy's Pro's cheap and retains stock suspension components. Con: can be sketchy, and rear brake line fitment.
-Mk2/Mk3 springs with HD struts: Pros easy to instal and gives a good lift. Cons: on bumps the struts hit full travel, rides rough, and might require modification of the springs for clearance
-Custom valved rally struts/coil overs: Pros rides great and has improved valving Cons: $$$$
-Superbettle struts up front, HD mk2s in the rear, and stock springs: Pros gives a lift without moddifying much Cons: axles can hit control arms, and you still use stock springs.
-Aftermarket coil spacers or strut spacers: Pros keeps stock suspension Cons: no longer avaliable
Common parts used that may fit:
-superbettle front inserts
-mk2/mk3 springs (requires some modifications?)
-Audi 4000 springs
-Porsche 944 Springs and struts
-HD Stuts
This is just what I have found from reading on the forums and would love to see pictures of your setups and hear about your experiences!
-Audi 4000 springs
-HD Stuts
