1 - 20 of 23 Posts
The Roof laights are Hella FF700's on the inside & Hella 500FF's on the outside - mounted to the rack via some small aluminum bars & some u-bolts. A Fishing boat Troling motor Deck connector was used to get powwer throught the roof.
Hella E-Codes - from Rallylights.
Low Beam:
High Beam:
& here are some pics (in daylight) from the high desert in Nevada on the way home:
Some videos of it in action:
Lifted MKII Golf Diesel TDI Conversion Offroad Videos
Discussion Starter · #8 ·
Re: Lifted MKII TDI Golf at Bonneville in the dark (_blix_)
Quote, originally posted by _blix_ »
lower it
I Did.
I had it up a little bith higher for a while & couldn't get the C.V joints to last... so i put it down a bit.
nice nuts!
thanks! I find that some people install nuts that are tasteless and offensive (and plastic)
I prefer Bold - Artistic - Functional nuts (of steel)
they serve as a great place to quickly hook the tow strap when i need to pull my friends busted GMC 2500DH up a hill.
that thing is sooooo bad ass, i love it
Very cool!
Thanks!
wow that's impressive.
It's Hella E-Codes from RallyLights (With a little help from our chineese friends on ebay.
love your car...
cant remember, isit synchro?
post some pics with a normal golf on the side lol
This one is not Syncro - Ben & I are currently converitng his Dark Red 4-Door to syncro. I wouldn't want to push this kind of torque through the syncro system. The VR6 clutch already has a strong distaste for me.
I already have the next project Golf II 2-Door with 89k miles that has never been hit. It will be getting a TDI & some other AWD Goodies...
& i will get some pics up of this with another golf... In fact i think my friend posted some in another one of my threads.
Modified by FrankenCar at 11:02 AM 10-9-2008
Discussion Starter · #10 ·
Re: (gti2.0vw)
Quote, originally posted by gti2.0vw »
how slow it that thing
Ummm.... well - it's amost entirely useless in first gear - so i guess in first it's soooooo slow it isn't going to go anywhere when you floor it.
& these tires are no longer in production - so i don't do that.
I guess it's quite fast? depends on what you thing fast is?
IT S-L-I-P-S the V-R-6 C-L-U-T-C-H!!! (when i mash on it in 5th with a load up a hill) (& they say this clutch is good to 300lbs)
here is all the info.
The Suspension:
16V Passat A-arms
R32 Bushings
MKIII Golf CL Tie rods
MKIII CV shafts
Bilstein HD Struts
Modified strut housings
Corrado rear beam (the next one will be Syncro... sorry... Haldex)
Modified Strut Housings (cut off & rewelded the part that holds the wheel bearing housing)
1" Machined Steel rear spacers
Passat VR6 Wagon Springs on all four corners
Rear Passat VR6 Wagon Upper spring mounts (Very different from golf)
The Wheel/Tire Package:
MKIII Flyer Wheels (14x6 et 45) with BFGoodrich All Terrain T/A tires (27x8.50r14)
& for mud:
MKII Teardrop Wheels 14x6 et 38) with Kumho Road Venture Mud Terrain tires (27x8.50r14)
Quite a bit of fender Trimming/Reshaping was needed (along with the lift) to clear these tires
The Rest of the Info:
The Brakes are all MKIII disk (4-cyl)
The Engine is a 1889 TDI (AHU)
pp764 Injectors
K03/K04 Hybred Turbo
3x11x27" FMIC
Mocal Thermostatic Oil Cooler
BleachedBora DP
2.5" Techtonics DP Back
Upsolute Stage 2 Chip
ARP Head Studs
Deleted A/C
Deleted Power Steering
MKIII Radiator
Custom Front Subframe/Crossmember (to hold FMIC, Radiator, Motor)
ClassII Hitch
EGT Gauge
Boost Gauge
Oil Temp Gauge
CB w/ PA
MKIII Style Door Hndles
Hella 700FF Lights x2 on roof
Hella 500FF Lights x2 on roof
Valley Industries Roof Rack on Thule Cross Bars
Re: Lifted MKII TDI Golf at Bonneville in the dark (FrankenCar)
Very nice! I wanted to do that to my 85. Do you think the taller tires are killing your clutch?
Discussion Starter · #15 ·
Re: Lifted MKII TDI Golf at Bonneville in the dark (allanmulwee)
Quote, originally posted by allanmulwee »
I think the TDI cranking out over 300 LBS of Torque is killing the clutch.
under most conditions it just accelerates - but if i am in 5th & have a trailer - or a load & a hill & i keep my foot on the floor at about 2000rpm long enough i can smell clutch a little bit. I have not been able to plot it with the VAG-COM yet as i havn't got access to it right now.
The tires only kill the fuel milege.
& so does the lift - & the roof rack - & the fact that all of the body under the front bumper is removed - & maybe the way i like to drive it.
I'm gettin about 33 - 36 mpg depending on how i use it.
- & that's incredibly bad for a TDI
Your girlfriend is either fed up or sleeping in the last pic.
hmm my buddy has a 2.9 VRT on 25psi.. and a stock clutch has been fine.. maybe its because it spins the tires till 4th gear?
EDIT: oh yeah, and too bad your golf wasnt syncro, that would be even more badass, and fun
Discussion Starter · #19 ·
Re: Lifted MKII TDI Golf at Bonneville in the dark (ABA Jetta II)
Quote, originally posted by ABA Jetta II »
Syncro would hate the torque. The nezt one will be Haldex.
ok, now for shots of you jumping baja style........and......now.
1 - 20 of 23 Posts
