1 - 7 of 7 Posts
The temp. control and air conditioner light went out tonight . I gave the cluster a light tap and it came back on . Did any one else have this happen to them ?. If so is there a bulb that needs to be changed of a loose wire connection? Is there only one bulb or several ? The car has 45000 km ..
2000 Jetta GLS Tdi
Silver Arrow \Black Velour
5 Speed
Cold Weather Package
Premium Member
Re: Light in temp/ air conditioner cluster went out (bssv)
It's one bulb. Take off the fan switch and you'll see the bulb. Pull it out and replace it. The same thing happened to our beetle. It costs 2 bucks to fix.
Re: Light in temp/ air conditioner cluster went out (adg44)
quote:[HR][/HR]It's one bulb. Take off the fan switch and you'll see the bulb. Pull it out and replace it. The same thing happened to our beetle. It costs 2 bucks to fix. [HR][/HR]​
how do you take the fan switch out?
Discussion Starter · #7 ·
Re: Light in temp/ air conditioner cluster went out (wsommariva)
yes , I got the switch out and the darling little thing is there . I never took it out , I'll buy one first -- change it on FRi.
1 - 7 of 7 Posts
