1 - 4 of 4 Posts
Discussion Starter #1
Alright, so the problem is pretty simple, yet highly aggravating. When i'm driving and step on the brake, this only happens every now and then but enough to make me worry, the headlights go out
What could the cause of this be? Possibly a bad ground? If so where at?
BTW its a 97 Jetta GLX
TIA
Re: Light issue need some input (jettagltrek)
Hey Jetta
Do they come back on immediately after you release the brakes? If not, try playing around with the ignition next time it happens... That's what caused my issues.
This might help: http://www.vaglinks.com/Docs/V...Y.pdf
Cheers
Massboykie
Re: Light issue need some input (Massboykie)
thanks for that DIY post i have been looking for that. added to favorites http://****************.com/smile/emthup.gif
i call ignition switch.
start car, turn on headlights, fiddle with key rather violently but not enough to turn the car off. You'll probably see the same symptoms.
1 - 4 of 4 Posts
