1 - 20 of 32 Posts
Below is the listed of TSBs for the new jetta.
http://www.halflifed.com/jetta/
Recall notice for 2005.5 2.5L VW Jetta
Safety Recall M1
VW letter to owner
Letter from DOT to VW
TSB For the 2005.5 2.5L VW Jetta
60-05-01 TB VW Sunroof and Central Control Module -J393- Diagnosis
69-05-03 TB VW AIRBAG/PYROTECHNIC SAFETY BELT DEP
70-05-01 TB VW FRONT DOOR PANELS RATTLE W/RADIO
74-05-02 TB VW REAR CENTER ARM REST,LOCK CYLINDER
94-05-02 TB VW TAIL LAMP ASSEMBLY,WATER INTRUSION
97-05-01 TB VW GROUND CONNECTION INSPECTION (BR)
97-05-02 TB VW REPLACE ENGINE HARNESS (B4)
00-05-03 TB VW XM SATELLITE RADIO EQUIPPED VEHICL
00-05-04 TB VW INCORRECT WHEEL COVERS
01-05-10 TB VW VARIOUS CONTROL MODEULES SPORADIC
23-05-03 TB VW INTAKE FLAP MOTOR V157 REPL END SO
55-05-01 TB VW FUEL TANK LID DOES NOT CLOSE,
57-05-01 TB VW DRIVER DOOR LOCK CYLINDER INOPERAT
91-05-01 TB VW RADIO, RECEPTION DIAGNOSIS
91-05-02 TB VW RADIO, ANTI-THEFT RADIO SECURITY C
92-05-01 TB VW WASHER JETS (FRONT OR REAR), RESTR
94-05-03 TB VW DAY TIME RUNNING LAMPS SWITCHED
01-05-05 TB VW IMMOBILIZER CODE, RETRIEVING USING
01-05-06 TB VW IMMOBILIZER CODE RET USING GEKO
17-05-01 TB VW ENGINE OIL,VW OIL QUALITY STANDARD
55-05-02 TB VW REAR LID, HINGE(S), BINDING
If you have a TSB that is not listed please send me a PM. I want to keep this post very neat as it will be in the Jetta FAQ section. Thank you to all those who helped.
Modified by Firedogut at 3:18 PM 7-28-2005
Discussion Starter · #2 ·
Re: List of the TSBs on the New jetta (Firedogut)
Quote, originally posted by utsava »
This is a great post! Hopfully it can stay updated, as it will be a valuable tool.
One interesting note about about TSB 23-05-03:
It speaks about what the service tech should do when encountering a "tuned" ECU. This includes having the owner fill out a form stating whether or not the car has been tuned and if so, what has been done. This is followed by a declaration allowing the dealer to flash the ECU, permanently erasing the tuning program and stating that all related warranties can be void.
Interesting....
Still looking for the following
Not Posted (if you got them send them my way)
anyone have them?
Discussion Starter · #7 ·
Re: (Pooz)
Quote, originally posted by Pooz »
Is there a subtle way to ask a dealer to check and see if any of those TSB's affect one's car or not?
why subtle? These TSB are open to the public. bring the list in and tell the dealer you want to talk about each one. Go thur each one and see if effects your VIN.
Re: (Firedogut)
Quote, originally posted by Firedogut »
Done and done... thanks http://****************.com/smile/emthup.gif
Discussion Starter · #9 ·
Re: (Pooz)
Just a little note. Dealers in my area where more then happy to provide copies of current recalls and TSBs. The list I posted above is just that, a list of current TSB as listed on the VW site put into a nice easy to follow way. I do not own or run a site that hosts the actual TSB, contact your dealer for the TSB. You can e-mail me if you have any questions.
Modified by Firedogut at 3:16 PM 7-28-2005
Hi,
Did any of you have any issues at the dealership? I just got an '06 jetta and have experienced at least one of those issues (the rattle in the door from the radio). This car is a huge improvement over the MKIV in a lot of ways. Only one downfall, the radio isn't all that: The 2000 model year half height monsoon stereo with the amp in the trunk was awesome.
Just my 2 cents... Any insights on the dealers would be great..
Thanks,
Clark
Re: (OGSN0)
What were they doing about the ECU's tuned? Wonder if that includes APR's software? Susposed to be undetectable by the dealer? Encripted?
Modified by GaBoYnFla at 4:31 AM 10-24-2005
1 - 20 of 32 Posts
