little help.
481 Views 7 Replies 7 Participants Last post by  eightvalvejettacarat
alrite, pop quiz hot shots. you have a stock 91 16v GLi and $1,000. what do you do?
what mods would you do.. (engine wise).
brand names would also help very much http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
...or should i put it in a swiss bank account and save it for a vr6 swap?? http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif
[Modified by FstrThnU, 7:00 PM 2-10-2002]
See less See more
5
1 - 8 of 8 Posts
Re: little help. (FstrThnU)
Don't spend it on the engine.
Buy a set of sway bars (anti-roll bars) by Neuspeed or Eibach and a full set of polyurethane bushes.
You will not be disappointed, trust me.
See less See more
id start with an intake system, maybe a k&n cone filter, ractive has some nice intakes as well, then some cams, adjustable gears, and plugs and 8mm wires!!!
that wouldbe a good start!!
Re: little help. (canadian_gti_mk2)
I'd prolly start by rebuilding the tranny
See less See more
2
TT matched 16v camset, valve springs, new valve retainers, stem seals.
thanx for the help..very much appreciated http://****************.com/smile/emthup.gif
See less See more
3
quote:[HR][/HR]id start with an intake system, maybe a k&n cone filter, ractive has some nice intakes as well, then some cams, adjustable gears, and plugs and 8mm wires!!!
that wouldbe a good start!![HR][/HR]​
not to sound like a smartazz, but it's gonna be pretty darn tough to fit a ractive intake to a 16V, unless you like to torture yourself with fabrication. you'd be better off to swiss cheese that airbox. as per the other suggestions, i agree. drop that sucker to the ground and get some sticky tires.
Re: little help. (3WheelGTi)
make sure your car is in mechanically sound condition... then i would upgrade the suspension if anything
1 - 8 of 8 Posts
