locking gas door swap
528 Views 7 Replies 6 Participants Last post by  bones2.8
how hard is it to put the locking gas door mechanism in? and where is it?
1 - 8 of 8 Posts
Re: locking gas door swap (28)
It's on the right side of your hatch / trunk, behind the carpeting. After you pull the carpeting you will see an area with an indent about three inches by one on the edge of the metal. It will have a couple of holes in it for fasteners/screws. The locking mechanism goes there.
Get a Bentley, it has all the information about removing and installing it.
Re: locking gas door swap (bialyorzel)
Way easy. You buy the gizmo from the stealership (or you can get a kit from one of the VW parts dudes here on the board, I forget which one), the part comes with its mounting screws, you slide it into the mounting (while poking the rod through the rubber thingy the door stops against), connect up the tubing (I used aquarium tubing) to the T connector behind the back seat (behind your kidney) under the carpet. The T connector has one part of it melted off, so use an exacto knife to CAREFULLY carve the melted part off (don't snip it with wire cutters like I did. It shatters like a cheap Tic-Tacs box). Plug in the tubing, mebbe use a little epoxy to seal it, and you're done.
Re: locking gas door swap (Mark1)
thanks guys, I actually have the parts I need off my wrecked GL
Potterman sells the complete kit if anybody else wants to do it...
i searched through potterman's site and couldnt find it, i need to pick one up! any other places besides the stealership???
Re: locking gas door swap (vento8valve)
anyone???
quote:[HR][/HR]i searched through potterman's site and couldnt find it, i need to pick one up! any other places besides the stealership???[HR][/HR]​
evolution sports (425)710-9200 evolutionsports.com
1 - 8 of 8 Posts
