Sorry for the late response, been juggling multiple things. So, replaced the starter, and that was that issue. Back to the main thing. I started to diagnose it then had to stop for other reasons. I found the radio was indeed unplugged, the +12v constant is getting +12, the switched is switched, and the ground is ground. The fuse, is blown, I'm suspecting something is shorted to one of the speaker lines. Probably what's causing the issue. (
EDIT: The fuse on the back of the radio will blow, not the main fuse in the block)
I also noticed by the lights of the lock switches, all the doors will "obey" lock signal, now I'm having a hard time recalling what I saw, but the rear driver door functioned fine, I forgot what door I was using but I could see all except the rear pass would follow unlocking and locking.
I can clearly tell someone has dug into just about every panel on this car, probably trying to find the root cause. So, I'm wondering what else has been unplugged and possibly replaced. With this I saw that both mirrors are replaced, both function. This looks like body shop work, and they are thinking it's a LIN system. Posted below is the original VCDS autoscan, I don't have a new one yet because somehow I managed to kill windows on my car laptop. Re-formatting it now.
I suspect the fault is going to be either a cut can wire or 12v something thats supposed to probably go maybe to the rear pass? and hitting a speaker? I didn't have the idea to test for voltage on the speaker lines on the harness at the time. What threw me for a loop is everything in this car is dated 2006, but it's a 2007, I also found indications (and eventually confirmed) it was in a small accident. Hopped a curb, took out what I assume was a lamp post, shattered the windshield, dented the roof, took off a mirror, and threw the FR wheel off enough it needs a good pound of lead to balance it (didn't notice on my original inspection because they were the inside stick on weights, I saw this replacing the starter) Trying to figure that out, (and had a theroy maybe someone re-pinned the radio connector to accommodate an after market stereo) the radio looks base, but says premium 7 on the side, weird as hell.
I googled every module PN to see if maybe someone swapped something for something they shouldn't have. One stands out, and I can't confirm it belongs in a 07 jetta LHD car. Address 46 Central Conv. 1K0 959 433 CD. In addtion, I found half a fob case cover, so I'm kinda wondering where the other parts are, maybe someone did the trick of taping it up around the ignition for some dumb reason, then someone went to re-program keys, and wasn't able to because of 2 keys being present, would explain why the FOB doesn't work, random idea anyways.
So far all I have done is pull the radio, and googled, mostly in confusion with the 06/07 thing then got real side tracked with investigating its ownership and eventually finding out what happened to it. Rabbit holed.
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 21.9.0(x64) Data version: 20210903 DS330.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,15,January,2022,15:57:40:00009
VIN:
VIN License Plate:
Mileage: 230900km-143474mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN:
VIN Mileage: 230900km-143474miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Sporadic communication error 1000
VCDS
Self-Diagnosis Log
Page 2
VIN:
VIN License Plate:
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 S HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9652
Revision: --H01--- Serial number: VWZ7Z0F4640875
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 397998E370599B4146-806C
VINID: 0E69D558705B0477402010470830E99776
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 230906 km
Time Indication: 0
Date: 2000.00.00
Time: 23:06:20
Freeze Frame:
RPM: 670 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 54.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.843 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 FL HW: 09G 927 750 FL
Component: AQ 250 6F 0920
Revision: 00H69000 Serial number:
Coding: 0000072
VCID: 000F350753030A8941-8054
No fault code found.
VCDS
Self-Diagnosis Log
Page 3
VIN:
VIN License Plate:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E56ACB12B521114C-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FQ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 78FF5DE70BD3424979-802C
VCDS
Self-Diagnosis Log
Page 4
VIN:
VIN License Plate:
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000486099
Coding: 14058E234004150007140000001400000008730B5C0000
VCID: 366393DF41477439AB-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 141106 020 0501
Coding: 00065535
Shop #: WSC 00066
5 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 95
Mileage: 223803 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
ON
01499 - Bulb for High-Beams; Right (M32)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 93
Mileage: 230792 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
VCDS
Self-Diagnosis Log
Page 5
VIN:
VIN License Plate:
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 93
Mileage: 230792 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 229407 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.95 V
OFF
ON
OFF
OFF
OFF
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 13
Reset counter: 93
Mileage: 230792 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.50 V
ON
VCDS
Self-Diagnosis Log
Page 6
VIN:
VIN License Plate:
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D06TPU.
Coding: 0013889
VCID: 6CD771B74F8BFEE98D-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME1249323E9
Subsystem 3 - Serial number: 6342MSME12350574%
Subsystem 4 - Serial number: 6351HSME0B1E0F65J
Subsystem 5 - Serial number: 6361HSME0B11124B%
Subsystem 6 - Serial number: 63727SME0B235D1D8
Subsystem 7 - Serial number: 63827SME0B232337Z
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0100
Coding: 0010021
VCID: 77FD5EDB06CD4D3170-8022
VCDS
Self-Diagnosis Log
Page 7
VIN:
VIN License Plate:
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 953 H HW: 1K0 920 953 H
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4640875
Coding: 0023203
Shop #: WSC 02146 067 57207
VCID: 306FA5C7A3235A09F1-8064
VCDS
Self-Diagnosis Log
Page 8
VIN:
VIN License Plate:
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069080933
Coding: 3FBF034007001002
VCID: 2C57B1B78F0B3EE9CD-FFFE
4 Faults Found:
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 41
Time Indication: 15
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 41
Time Indication: 15
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 41
Time Indication: 15
01304 - Radio
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 000
VCDS
Self-Diagnosis Log
Page 9
VIN:
VIN License Plate:
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Shop #: WSC 06402 145 00197
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 223807 km
Time Indication: 0
Date: 2000.00.00
Time: 00:02:25
VCDS
Self-Diagnosis Log
Page 10
VIN:
VIN License Plate:
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000073169022
Coding: 0001205
VCID: 3B7582EB7A65A95154-806E
5 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 55
Mileage: 223911 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Reset counter: 55
Mileage: 223851 km
Time Indication: 0
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Freeze Frame:
Fault Priority: 3
Fault Frequency: 74
Reset counter: 94
Mileage: 227808 km
Time Indication: 0
00100 - Drivers Interior Locking Button (E308)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 230871 km
Time Indication: 0
00104 - Fuel Tank Lid Unlock Button (E319)
007 - Short to Ground - Intermittent
Freeze Frame:
VCDS
Self-Diagnosis Log
Page 11
VIN:
VIN License Plate:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 31
Reset counter: 88
Mileage: 223928 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3467A9D7573B662995-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 74E769D717BB262955-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
VCDS
Self-Diagnosis Log
Page 12
VIN:
VIN License Plate:
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000126469025
Coding: 0001204
VCID: 3C7781F77F6BAE695D-8068
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Freeze Frame:
Fault Priority: 5
Reset counter: 95
Mileage: 228547 km
Time Indication: 0
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000614020
Coding: 0001168
VCID: 3E738BFF6977BC7973-806A
VCDS
Self-Diagnosis Log
Page 13
VIN:
VIN License Plate:
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0420
Coding: 0100101
Shop #: WSC 131071 1023 2097151
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 228569 km
Time Indication: 0
Date: 2000.00.00
Time: 02:47:41
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000736168
Coding: 0001168
VCID: 3F8DF6FB6E7DB57178-806A
End-------------------------(Elapsed Time: 02:00)--------------------------
