Re: Losing Brake Fluid (Strobe)
well the only fluid in the tunnel is fuel. make sure that you dont have a fuel leak. give it a good sniff. your brake fluid resivoir is located up top and i seriously doubt that brake fluid could make its way to the front like that. but anything is possible. check on the floor board in front of the master thats a common leak place. and follow the brake line from front to back and check for leaks. also the blue hoses fro resivoir. they tend to crack. and have you pulled the drums to check the wheel cyls? if its a slow enough leak the brake shoes and dust tends to soak it up. hope this helps
