Hi all,
I hope I post in the right sub-forum.
My driver window is loosing its feature to one touch automatic close/open. While my other 3 window one touch works fine. Several things I already try to restore the memory of it =
1. Hold down the window until the full open ends and holding the button for 15 second. Then hold up window until the full close top end and holding it 15 second. But not work.
2. Hold down the window until the full open ends then release, and then holding the button for 15 second. Then hold up window until the full close top end then release, and holding up again 15 second. But not work.
I have OBDeleven scanning tools, I already scanned all and no faults in every module. However, I found in my live data something different.
Window regulator (V147) in my driver side state = positio bottom. While window regulator (V148) in my passanger side and other rear both side state = end stop gel.
I also checked with my friends car with the proper one touch function, the window regulator should be stated = end stop gel.
Any toughts.?
Thank you for your help.
It's not a volkswagen, it's just a car
Any toughts.?
