Ok here is the issue explained fast...
2 cars different cars, same problem.
Leon Cupra 1.8T
Subaru Imprezza wrx 2008...
BBK 13" 8 piston
On a track day after 5-6 laps from one turn to the next, braking simply was CERO!!.. and brake pedal went all the way down! pumping it real fast got 20% braking back... so down to pits... no leaks, bleeded again, and off to the track once again...
7 laps later... same problem!!! no spongee pedal feel, no fading, just brake all the way down and no braking with out warning!!!
Both cars have the same issue... more less same number of laps from each other, no leaks, no visual problem..
if Master cylinder fails, it wouln`t recover braking again I suppose? so why we were abble to race several times again, just waiting for it to happen again, and it did...
Brake pads are for up to 800ºC (1472ºF) and I know (maybe wrong) when pads exceed the working temperature pedal feels spongee and braking is reduced, but never brake goes all the way down and get no braking from one second to the other!!!
Talked to the BBK company and they are "checking" since they have had never this issue so they point to a problem not related to the brake kit..
the most weird thing is that happens exactly the same on 2 different cars/brand/model !!!
thanks!
Modified by surfo at 10:07 AM 4-26-2010
Leon Cupra 1.8T
BBK 13" 8 piston
thanks!
