Re: low gas milage
(MrMiesta)
The valve is one part of the original decelerator control,designed to dampen the action of the throttle when you pull your foot off the gas pedal,the hoses and other valve that should be connected to the carb are all missing.The missing valve controlled an adjustable rod that was connected to the throttle arm about halfway up,the ball pin sticking out to the right.
The larger hose that seems to come from,and go nowhere,is one part of the fuel vapor recovery system.
If the throttle is allowed to snap closed when you remove your foot from the pedal to brake,the engine tends to get drowned for a moment while the fuel in the intake manifold continues to drop into the cylinders without the proper amount of air to accompany it,creating a short rich condition,slowly building up deposits on the plugs,lowering your gas mileage.It was intended to work in concert with the vacuum advance on the dizzy,which looks like the wrong one for your application.There's a vacuum port plugged off on the carb which should be connected to the backside of a dual diaphram unit.
The hose to and from nowhere,disconnected,allows fuel vapors to freely vent into the atmosphere.Put 10 gallons in the tank and park it for a week,you'll find only about 9.5 gallons left due to evaporation.In a very subtle way over time,evaporated gas that you bought and paid for just isn't there anymore to fuel the car,lowering your mpg calculations.
Both were components of early smog control efforts.
As stated in other recent threads,please find a way to remove the fuel filter on the high pressure side of the pump in order to avoid a fire.
Modified by buggyman at 12:29 AM 8-22-2006
Modified by buggyman at 12:35 AM 8-22-2006
