So here is the initial build-up.
I started with the DIY kit from [email protected], with the firestone rears, firestone fronts, HPS short struts, and the AVS 7 switch. Viair 400c 150 PSI Compressor, 5 Gallon tank, 8x Asco 300 PSI 3/8" Brass Valves.
I live on the top floor of my building with outdoor only parking, so there won't be any fancy garage pics. This is also my daily, so anything I do has to be put back together and road worthy at the end of the weekends.
My completion deadline: First weekend in June.
What I have so far:
The aluminum bit in the middle is something i turned at work. I'll be able to bolt this assembly to the bottom of the wheel well using the existing threaded part that formerly held down the spare tire.
let me know if you have any advice or if you can point out anything not looking quite right.
Oh, btw, Everything is going in this bit of glory:
Modified by Devo! at 1:38 AM 5-14-2009
Modified by Devo! at 11:36 AM 5-23-2009
What I have so far:
