1 - 5 of 5 Posts
Re: low pression (NORDLAND)
with 8.5:1 compression you can definitely run a lot more boost than 8psi as long as you have big enough injectors. if you never plan on running more than 10psi you can get away with 9.5 or 10:1 no problem on pump gas and make a lot more power than you would with 8.5:1
Re: low pression (92g60gti)
Quote, originally posted by 92g60gti »
... if you never plan on running more than 10psi you can get away with 9.5 or 10:1 no problem on pump gas and make a lot more power than you would with 8.5:1
What kind of timing and egt would you run with that?...where would the motor be on the compressor map with that turbo?...as opposed to the 8.5 motor at say 15 psi.
What would the power difference be between the 10-1 motor at 10 psi and the 8-8.5-1 motor at 15 psi on pump? Surely you must have some experience with this.
1 - 5 of 5 Posts
