Lowered my TT: ISC N1 Street Sport Package
Finally, found the time to address the heinous OEM wheel gap on my '11 TT 2.0 TFSI w/vl.
I had a set of ISC N1 coilovers with camber plates and spherical bearing mounts installed by a semi-local shop, Roc-Euro located in Rochester, NY.
Currently stance needs some work. Rear is sitting about an inch lower than the front and wheels need to be pushed out a bit to get flush with the fenders.
The dampers are currently set at click 6 of 32 clicks (32 being the firmest). Damping feels OEM until you hit a harsh bump. You're then quickly reminded that you have much stiffer springs and the OEM rubber strut tops are no more!
The kit
OEM wheel droop
OEM rear coil vs. ISC rear coil
ISC N1 droop
They're not V3's but certainly good bang for your buck.
The kit
OEM wheel droop
ISC N1 droop
