1 - 8 of 8 Posts
Re: lowering caps (mack16v)
take of the stock caps and isntall the lowering caps...should be a direct replacement.... and welcome you must be new.
Is there any chance i can have you snap a pic of the stock caps next to the lowering ones. i just want to see exactly how they achive the drop.
if you don't have lowering springs in there already, getting the caps in requires spring compressors- they are loaded up with a couple hundred pounds of pressure and if you just unscrew the top you could die.
Re: lowering caps (tkic)
Quote, originally posted by tkic »
yea i almost killed a shin doing that... http://****************.com/smile/emthdown.gif
what else to do without a spring compressor.
Discussion Starter · #7 ·
Re: (wantacad)
as soon as i take them out you will get the picture http://****************.com/smile/emthup.gif
1 - 8 of 8 Posts
