Finally got the carpets out and found this
Driver’s side isn’t horrible but the passenger side certainly is. I’m debating welding in new pans and being done with it, but seeing as the rust is all along the seam here and I’d have to do a bit of fabrication anyway I might just try and patch the really bad spots and hit the rest of the floors with rust converter/bedliner once I’ve gotten the leaks fixed up by the windshield / rain tray.
Took Lula to the car wash under the guise of finding where the leaks were coming from (really because i have an insatiable urge to pretty up new car, no matter how much of a pooch it is) and boy, did I find some. That passenger side leak let about a quart of water into the cab over the course of the wash, and there appears to be a small leak on the drivers side rear as well. I expected it given that every rabbit I’ve ever seen leaks water, but that don’t make it less of a pain to track down n deal with.
She ain’t winnin any beauty contests, but my heart still beat a lil faster giving her a walk around after the wash.
I brought the carpet with me, which you can see in the bed, and gave it a 10 minute once-over with the soap from the pressure washer. The water was still running frothy brown by the time I lost patience and decided I’d just get a new carpet down the line.
Quick question for you guys: What’s the deal with this new injection line I swapped in? It fits perfectly on both ends, but sits about a half centimetre off from the rest of the injectors on that first bend from the pump, to the point where I’m not able to get the lower anti-vibration clamp on - not even close. I’d think if it was made for a different injection pump / different pump position then it wouldn’t bolt up, but it fit perfectly. Obviously I’d like to have that lower clamp on if I can, but I’m not sure if it’s worth trying to bend or modify this new line or whether I should just swap the whole set over that I got from Ron. Any thoughts? The upper clamp fit fine so at least it has somethint
Finally, just gonna dump some ideas here for where to move this forward to. I’m feeling like this is a pretty good starting point for a more ambitious project than I’ve attempted in the past, and I’ve just sold my other truck, a ‘92 diesel Land Cruiser, so I’ve got the funds to do some bigger modifications. My thoughts so far:
Sand, patch and repaint entire body - I’m thinking of going with a sort of chestnut brown that I once saw on a ‘64 Ranchero I almost bought back in Washington… one of my biggest car-related regrets passing up on that one. I don’t have any pictures of it, but I’ll look for some examples of the colour. Probably set up a booth in my garage in the spring, before it gets way too hot here to be in coveralls and a respirator all day.
Figure out some sort of turbo setup. I’ve never installed a turbo personally but my Land Cruiser had one - even weighing 4500 pounds, with a 2.5l engine, that turbo would send that thing up hills and mountain passes like they were nothing. Totally changed my perspective on diesels, thinking they were pretty much only good for making power down low. Again, this is something I have pretty much no knowledge of, so I’d really appreciate reading any recommendations or experiences you all have had with turboing your diesels, especially your 1.6s.
Fab up a bench seat for the truck - just a personal preference of mine. I sewed a vinyl seat cover for my old 77 f150 a couple of years ago that turned out really nice, but sold it right after completing it, and recently foamed and hand stitched a leather seat for my motorcycle, which I never got to use before my bike got totaled… so I’ve still got the urge to park my ass on something I had a hand in making! I’m gonna do some research on other compact pickups and see if I can maybe use the frame and mounting points from an old Toyota or Nissan truck as a starting point, basically cut out and weld in the frame and then build the seat around it. The trick will be getting everything situated so the seat fits and is actually usable, plus moving the e-brake, maybe to where the hood latch is right now, or to a pull handle in the ashtray spot. We’ll see what works.
Last, well probably first in terms of what will actually get done, i wanna re do the whole fuel system, which again is something I don’t have any experience with. The filler neck leaks and the cap doesn’t seal, and who knows what the tank is like; I’d like to learn to make up hard lines and clean/reseal fuel tanks and feel this will be a good truck to get some experience with.
Well, that’s all for now. The only thing I got around to worth sharing is installing this old beige grab handle I had laying around, to match the seat. I honestly feel like the two tone thing looks pretty good lol
