1 - 20 of 90 Posts
July 30, 2015
Current mods:
Engine & Transmission
Neuspeed Power Module
BMS Pedal Tuner
APR Intake
APR Turbo Inlet pipe
APR Turbo Inlet
APR Boost Tap
Euro Intake Manifold Cover
Audi S3 Resonator Delete
034 Motorsport Billet Aluminum MQB Dogbone Mount Insert
VWR Short Shift Kit
42 Draft Designs Solid Shifter Bushing Kit
HS Tuning RSR Hybrid Clutch
OEM Clutch Delay Valve Removal
Clutch Assist Spring Removal
Suspension, Wheels & Brakes
19x8.5 et44 OZ Superturismo LM's on Continental ContiSportContact 5P
19x8 et50 VW Cadiz on Firestone Firehawk Indy 500's
Eibach Pro Kit
isweep 1500 Front Brake Pads
OEM Euro Performance Package caliper covers
Interior
P3 Cars VIDI Gauge with Analog Boost Sender
Hard Wired Passport Escort Max
12V Outlet Always On
Leyo Motorsport Multimedia Ring Kit
Euro Rear Headrests
OEM VW Golf Monster Mats
OEM CarGo Protection Mat
OEM Cargo Net
OEM Centre Console Rubber Mat
OEM Warning Triangle
OEM First Aid Kit
OEM Torch Light
OEM Audi Aluminum Accessory Plug
LED Hatch Light
LED Glove Box Light
Exterior
OEM Cherry Red LED Tail Lights
BEC Dynamic Turn Signal Adapters
Drivers Side Euro Aspherical Mirror with BSM
OEM Stainless Steel License Plate Frame
LED Reverse Light Bulbs
Philips CrystalVision Ultra H7 Cornering Bulbs
VCDS Tweaks:
Comfort opening and closing windows
Passenger mirror dip in reverse
Heated seat setting retention
Fan speed indicator on auto
A/C set to colder tuning cooling operation
Litres to fill in MFD
Service indicator at 7500kms
Off-road monitor in infotainment
MFD skin change
Headlights coded to ROW
Auto high beam assist
DRLs only for coming/leaving home
Disabled side marker leds
Hazard lights flash on hard braking
Comfort turn signals to 4 flashes
Lane assist interaction set to early
XDS set to medium
Starting vibration reduction normal
RPM idle correction +50
Disabled warning tone with ignition on and drivers door open
Soundaktor at 50% volume
Video-in-motion
Discussion Starter · #6 ·
Picked up an APR intake and ordered Neuspeed 19x9 Rse10's and a Neuspeed Power Module. Now if only the car weren't 2 months away!
Discussion Starter · #7 ·
Discussion Starter · #9 ·
Discussion Starter · #10 ·
Car's actually been in Halifax since the 21st. Hoping its on a train shortly.
Discussion Starter · #12 ·
She's here!
Discussion Starter · #17 ·
Waiting for delivery. Picked up the car Friday October, 9.
Discussion Starter · #18 ·
First mod. Day one.
Discussion Starter · #19 ·
A few OEM goodies...
1 - 20 of 90 Posts
