LED lighting... before and after.
Nice! Stock height? Any spacers?19x9 RSe10's installed on factory Conti's.
I'd check that backend for strut pucks. Looks tilted upward.Nice! Stock height? Any spacers?
They don't use strut pucks in the rear. :screwy:I'd check that backend for strut pucks. Looks tilted upward.
Stock height. No spacers. 19x9 et45 fit perfect.Nice! Stock height? Any spacers?
Looks perfect! :thumbup:Stock height. No spacers. 19x9 et45 fit perfect.
I called 3 dealers before ordering and all of them recommended 9's. The 8" setup would sit exactly the same as the stock wheel so you'd end up running spacers. Seems backwards. In all honesty I think an 8.5 would be the perfect solution but almost everyone who sees the car comments on how perfect the fit is.Love the way those neuspeed rse10s look on you car. I also have a white R. Just curious as to why you went with the 19X9s over the 19X8s. From your pictures it seems like the stocker tires are stretched a bit on your 9inch wheels.
cool thanks for the info!I called 3 dealers before ordering and all of them recommended 9's. The 8" setup would sit exactly the same as the stock wheel so you'd end up running spacers. Seems backwards. In all honesty I think an 8.5 would be the perfect solution but almost everyone who sees the car comments on how perfect the fit is.
Do you have the part numbers for warning triangle and console liner?
Thanks!
Triangle part# 1y0093055.Do you have the part numbers for warning triangle and console liner?
Thanks!
Warning triangle no... sorry... I've had it for close to 10 years... fit in my Audi A3 and then used it in my Mk6 R. Liner yes... 5G0 863 328 L 82V.
Thanks!Triangle part# 1y0093055.
