what is the right way to modify your wheelwell to fit 14x7 or wider rims to a cabby?im also having problems finding places to buy 14x7 rims.seems only panasport is the only one outside of ordering from overseas.
okay if you use a dremel tool to cut away the lip that you attach the fender flare to do you just epoxy the flare back on to the sheetmetal since there is no lip to screw it back onto?
quote:[HR][/HR]okay if you use a dremel tool to cut away the lip that you attach the fender flare to do you just epoxy the flare back on to the sheetmetal since there is no lip to screw it back onto?[HR][/HR]
Well I didn't use a small Dremel to cut my lips away but uses some thing a little bigger and more professional (German qualtity tool).
My plan is to glue the flares on the top where I have cut away most of the lip (where you need to cut) and on the sides I use some small screws/glue.
This is on my project car. Look in my sig. for pic.
I had to roll my fender's in the rear to keep my weezee's from rubb'in...
The base ball bad method wook's great!!!!
METRODUB< http://****************.com/smile/emthup.gif
i didn't use any fancy german tool or dremel tool. just an old fashion louiseville slugger. it worked well for my application (h&r coilovers).
take care,
nash
I hate the look of plastic on my car. But that's just me. I'm gonna be doing some serious clearancing when my 14x8 et15 wheels come in.......
Especially considering I'm running 60mm springs. Hmm.
I need to clarify something about the suspension on the mk1 golf. On my project car I am going to run 8x15" offset18 with 195/45-15" and to be sure I got enough space for my wheels I took out the springs/bump-stops and put a jack underneath the ball joint and jacked the suspension up all the way until the bottom part of the strut hit the top spring perch (No more travel). See picture below for maximum lowering with original struts (Do remember that the wheel on the picture has a smaller diameter than the original).
The only way to get the wheel further up is by using a coil-over kit with shorter strut.
I want to have this as the ride height, but it all depends on the lowering kit I am going to use (Spring stiffness and max. travel).
The front wheels will pass underneath the flares to give me some travel. Hopefully
PDX Cabby has the solution. I'm fond of rolling with a baseball bat (in warm temperatures) as opposed to removing metal. It's faster and works just the same; with the exception of a few wheel sizes.
You might check out some of the advertisers in the back of Grassroots Motorsports for some 14x7's. I do know that it is not a common size with our bolt pattern. I'm sure that some Miata's are running them, you might look at http://www.Miata.net
VW Vortex - Volkswagen Forum
