1 - 5 of 5 Posts
· Banned
I still have a modified G in my car now it has upgraded seals bearings etc..and had the port cleaned up a bit, it has 30k on it with a 68mm pulley and runs at full boost and pulls like bitch...I have access to a recently rebuilt and "upgraded " m62 charger from a SC fella is it worth it power wise as far as an upgrade goes to do this? They are pretty cheap to rebuild compared to Gladders because of the popularity...BTW I am upgrading to 30# injectors and an overkill Granatellie 255lph pump along with a new SnS chip.
TIA
Steve
"inconstant search for more power"
Re: M62 swap for the GLADDER...is it worth it? (SlickG60)
if your g is in good shape i wouldnt do the conversion......its a real pita....i know ive got a brand new (4th gen.)m62 in my corrado and believe me it was a pita because of all the custom work that had to be done......however 22psi is kinda nice
Re: M62 swap for the GLADDER...is it worth it? (joeZX6)
WOW, you getting 22PSI out of it ?!? (That is 1.5bar...like I run my Polo
Did you change the pulley and IC-setup like you sad you wanted it done?!
Oliver
[Modified by oRz-Motorsport, 10:09 PM 11-30-2001]
1 - 5 of 5 Posts
