1 - 20 of 96 Posts
To see my old FBO K04 setup click here.
The K04 was a great turbo... It provided the perfect balance by giving quick spool up and providing solid power throughout the rev range. Mated with the DSG, this combination proved to be nearly unstoppable on the streets for some time. But it wasn't enough and now here we are... :screwy:
2012 GLI DSG Base - Frost Silver Metallic
Engine:
  • Rods: IERHVT2 (rifle drilled)
  • Rod Bearings: ACL race series
  • Pistons: Mahle MAH-PST2 83mm
  • Main Studs: ARP-204-5408
  • Head Studs: ARP-204-4302
  • Valve Springs: IEVTVT2
  • Exhaust Valves: FER-TSI-F2178P 1mm over
  • Intake Valves: FER-TSI-F2180P 1mm over
  • Exhaust Manifold: FFE vband tubular w/1.5inch SS piping
  • Turbo: Precision CEA 5858 ball bearing turbo, SP 4" ported housing, .64 A/R vband in and out hotside.
  • Wastegate: Tial MVS v-band 38mm
  • W/M: Aquamist HFS-4
  • Motor Mounts: SPM Full Motor Mount Kit
  • Tune: Unitronic Custom BT Tune
  • Unitronic 3” Exhaust
  • Unitronic High Output Fuel System
  • CTS Intercooler
  • CTS Catchcan
  • Neuspeed - HI-FLO Air Charge Pipe
  • Custom Discharge Pipe
  • Forge - Billet Oil Cap
  • Forge - Billet Coolant Cap
  • JCaps - Washer Fluid Cap
  • R8 Coilpacks
  • Some NGK plugs
  • Custom 4" Intake System
  • Powder Coated: Valve Cover/Lower Timing Cover/Oil Pan/Passenger Mount
  • Cerakote Exhaust Manifold/Turbo Hot Side
  • Basic Engine Bay Tuck
  • Relocated Battery in Trunk
Transmission:
  • Unitronic Stage 2 DSG Flash
  • Redline DCTF
Suspension/Braking:
  • 18z Calipers
  • RB ET Performance Pads
  • RB 2 Piece rotors with ventilated slots
  • SS Lines front/rear
  • Custom Billet Caliper Carriers
  • Porsche Cayenne Turbo 4 Piston Calipers (rear
  • Viper E-Brake Calipers
  • ST Coilovers
  • SPM Torque Arm Insert
  • Whiteline Front Sway Bar
  • Whiteline Rear Sway Bar
  • Whiteline Rear Sway Bar Link Assembly
  • Unibrace XB/XA
  • Rear Brake setup to be listed soon
Interior:
  • Podi Single Column Mount 0-30 Boost Gauge
  • GFB Geforce II Electronic Boost Controller
  • ESC Switch (Traction Button)
  • Euroswitch
  • USP LED Interior Lights (full package)
  • Carbon Fiber DSG Paddles
  • 3M Di-Noc'd the Interior Trim
  • Clarivue Head Unit Screen Protector
Exterior:
  • Euro Hybrid Style Projectors (Lamin-X Filmed)
  • 35% Solar-Tek Tint
  • USP 4300k HID Low Beams/Fogs
  • USP LED License Plate Lights
  • Dubstop Blue Aspherical blind-spot mirrors
  • Unitronic “Stage 3” Badge - Rear
  • Michelin Pilot Super Sport (235/40/18)
  • 18x8 Neuspeed RSE12
Stay tuned this should get interesting...
too late pattrick02 already did this and then some! oh and wide body and baller BBS LM wheels, but good luck regardless :laugh::wave::thumbup::thumbup:
If build threads were only allowed if you're the first, then 90% of the build threads would disappear since they're all bagged Jettas.
:facepalm: anybody who knows me here knows that I was joking, I would never maliciously take a swipe at someones build small or large like this. I have some plans for my car for next spring body wise but this is still very intriguing and look forward to seeing the end results of this :beer::wave:
Guess it's hard to tell sarcasm over the interweb. :laugh:
well ill give you that. but I assumed all the emoticons I put at the end should've made it sound humorous and not with malicious intent. that said the looks VERY promising :beer:
Sweet build. I noticed you had the APR v3.1 tune with your k04. Why didn't you got APR GTX turbo instead? Not enough power?
Isn't the APR stage 3 and 3+ still canned tuned? If I was going BT Id want a tune designed specifically for my car. Who knows how refined their stage 3 files are.
Wow that's a lot of engine mods :thumbup:
1 - 20 of 96 Posts
