1 - 5 of 5 Posts
I was having problems with my maf, replaced it, replaced the connection housing and that got rid of the code for maf voltage too low. Now I am getting a code for signal too low. I was planning on cleaning my new maf sensor, but I came across this thread that was talking about vacuum. Since I installed my new line from the fpr to intake mani, ive had vacuum at 20-21 hg at idel and when off the throttle in 3rd gear im seeing 26-27 hg. Is this causing my maf signal too low code?
heres the link
http://forums.vwvortex.com/zerothread?id=1205235
Modified by DubAdicted at 6:28 PM 9-23-2004
Discussion Starter · #4 ·
Re: MAF Signal LOW (dustygti82)
my housing is on the correct way. Does it matter for the sensor itself though? If you are looking in the housing does it matter which side of the sensor is facing left or right?
1 - 5 of 5 Posts
