Hello my good sirs..
I built a glowplug relay setup a la Vince Style, and it works superbly as it should. However I want to intergrade the stock wiring in to what i have got. I want the stock relay and wiring to trigger the relay and sense the coolant temp so it will be left on for however many seconds it needs. I would also like to leave in the manual switch i have on the dash, so that i can trigger the relay for afterglow 30-45 seconds after the car has started.
The Ford Starter relay;
I have the relay grounded to the body, one large gauge wire from the starter post, and the other to distribution block for the gp's. The relay is triggered by a low amperage 18-20awg wire from a switch on the dash to the "S" terminal of the relay. Will the relay work the same way if I were to hook the relay trigger wire up to the "I" terminal?
What I want to do is just take the wire that originally powered the buss bar, and connect it to either the "S" or the "I" of the starter relay. that way the stock system could power the relay or my manual switch could power it depending on the conditions.. Will having the two power sources on the same pole feed power back through the other and cause problems? Will running the manual switch on the "S" terminal and the stock wiring on the "I" terminal work?
ALSO SOME GOOD NEWS, dug the car out of the snowbank it was burried in and it started right up without hesitation... and without the cold start (I have the pump timed to 1.02mm). It was roughly -15 to -20 outside, and 30 seconds of afterglow on the Duraterms reduced smoke after only the first 10 seconds of running.. after that smoke was not visible. Also I did not have to prime the pump with the primer ball in the engine bay.. pump doesn't loose prime.. a very good sign. I have high hopes for this little 900k km engine
What do you guys all think?
