1 - 19 of 19 Posts
Banned
INTRODUCTORY OFFER!! FREE SHIPPING IN THE CONTINENTAL USA ON ALL PRE-ORDERS THROUGH OCTOBER 31, 2008!!! *
MASON-TECH.com is proud to announce the release of our brand new mk4 Sumpsaver Skidplate!!
A little bit about our skidplates...
Each Sumpsaver Skidplate is precision CNC laser cut from premium 3/16" thick aluminum alloy for superior strength and light weight. Mounting hardware is CNC machined and assembled with bulletproof corrosion resistant hardware. The smooth design means there is absolutely nothing on the underside of the skidplate to catch on road debris. Our unique front crossmember and 1/8" thick laser cut/TIG-welded mounting plates provide extra support that others don't. Designed to mate up with your OEM side splash shields, too! We did everything we could to make sure your oil pan and bellhousing are securely covered to prevent damage!
Installation is very straightforward. We designed the plate to fit YOUR car by incorporating slotted fastener holes and a unique mounting system. Best of all, we've also designed this skidplate to fit all engine combinations in mk4 Golf/Jetta chassis. Fits with most aftermarket front-mount intercooler setups, too!
What makes our Sumpsaver Skidplate so hot:
CNC laser cut and bent for a perfect fit!
No holes or cutouts to get caught on road debris!
CNC laser-cut and TIG welded front crossmember and mounts for extra strength!
Unique, easy-to-use hardware kit included!
Fits tight to car to provide as much ground clearance as possible!
Please note: Photos are of our pre-production prototype. Actual production units will be scratch-free. We are expecting to start shipping all orders approximately October 31, 2008.
Fits the Following:
mk4 Golf, all (VR6, 1.8T, 2.0L, TDI)
mk4 Jetta, all (VR6, 1.8T, 2.0L, TDI)
mk4 Golf R32
mk4 Golf/Jetta Sumpsaver Skidplate -$324.99 Buy Now!
Shipped FREE in the Continental USA! **
$20 S&H to CANADA! **
** To receive the special shipping price, you must select "USA Skidplate Special Shipping" or "Canada - Skidplate Special Shipping" method when completing your order online. Note: You must click the "Calculate Shipping" button after you select the shipping method.
We also manufacture many other unique products like Air Ride Suspension Kits and also offer a complete selection of vr6 timing chain kits and OEM parts as well as VR6 timing chain kits and components at excellent prices!. Check it all out at MASON-TECH.com
You may order online 24/7 at our secure webstore by following the links above or you may email us any time at [email protected]
Modified by [email protected] at 10:17 AM 10-29-2008
Banned
Discussion Starter · #6 ·
Re: (RedRThirtyTwo)
Quote, originally posted by RedRThirtyTwo »
looks thin
It's 3/16" 5052 aluminum. Same material we use for our mk2/3/Corrado skidplate. Trust me, it's strong stuff! Plus, with the front crossmember, it's got plenty of strength. http://****************.com/smile/emthup.gif
FV-QR
Any pictures of it installed?
Banned
Discussion Starter · #11 ·
Re: FV-QR (KoolTrix)
Quote, originally posted by KoolTrix »
i'll try this AGAIN.
call me a noob; but what are these? where do they go??
Sorry I missed you the first time! These brackets bolt to the underside and outside of the frame rails, just behind the core support.
1 - 19 of 19 Posts
