Mazda 6 Hatchback and Wagon a GO!
1540 Views 24 Replies 18 Participants Last post by  wdegroot
3
http://autoweek.com/cat_content.mv?...=carnews&loc_code=index&content_code=09549850
http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
1 - 20 of 25 Posts
Re: Mazda 6 Hatchback and Wagon a GO! (NegatiZE)
i wonder what the hatchback will look like?
2
The hatchback looks stunning. If they can put a turbo in, it will be a reincarnation of the early 626 Turbo hatch.
See less See more
2
Re: Mazda 6 Hatchback and Wagon a GO! (mmm_hmm)
quote:[HR][/HR]i wonder what the hatchback will look like?[HR][/HR]​
A bit like that, perhaps?
See less See more
This is going to be a very interesting time for the revived performance car market...
See less See more
2
Re: Mazda 6 Hatchback and Wagon a GO! (Suparu)
Too bad my brain is more interesting on deciding what to get....
[Modified by A4Jetta, 9:08 PM 2-6-2002]
See less See more
3
Re: Mazda 6 Hatchback and Wagon a GO! (A4Jetta)
quote:[HR][/HR]The hatchback looks stunning. If they can put a turbo in, it will be a reincarnation of the early 626 Turbo hatch.
[HR][/HR]​
That would be.... sweet...
See less See more
3
Re: Mazda 6 Hatchback and Wagon a GO! (anarchyx34)
More appealing than anything Mazda makes right now.
(miata doesn't count)
See less See more
5
Re: Mazda 6 Hatchback and Wagon a GO! (Enthusiast)
Mazda http://****************.com/smile/emthup.gif
The Mazda 6 http://****************.com/smile/emthup.gif
5 door sedans http://****************.com/smile/emthup.gif
Altezzas and boy racer styling cues http://****************.com/smile/emthdown.gif
I love the car but I would have to swap the damn altezza tail lights out for normal ones before I would be seen in it, sorry.
Altezzas = SH1T
See less See more
Cool http://****************.com/smile/emthup.gif
I wanna see the wagon...
See less See more
Re: Mazda 6 Hatchback and Wagon a GO! (Malathion)
Have they changed the tailights to non-Altezza ones similar to Matrix for production version?
See less See more
2
quote:[HR][/HR]Have they changed the tailights to non-Altezza ones similar to Matrix for production version?
[HR][/HR]​
Take a look at this...
Is it me, or are those taillights blacked out with chrome bezels? :s'y:
See less See more
Re: Mazda 6 Hatchback and Wagon a GO! (Apollo-Soyuz 1975)
hold up, !!!!
3.2 inline 4 or an optional 3.0 V6?????
is there a type-0?
hope its nothing like the mx3's 2.5 V6 with 130 hp
...if you're into that kind of thing.
3
Re: Mazda 6 Hatchback and Wagon a GO! (VeeeDoubleU)
The MX-3 V6 was only a 1.8
And I, for one, hope it IS a lot like the K-Series V6. That's a wonderful little engine.
http://www.bradbury.cwc.net/probemx/index.htm http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
Re: Mazda 6 Hatchback and Wagon a GO! (JrodVW)
Proposed engines are:
2.3L 4-cyl, new engine designed by Mazda w/variable valve timing and I believe variable intake mated to a new tranny. This should be a nice engine with rumored output in the ~165hp range.
3.0L 6-cyl, Built on Ford's Duratec w/heads & intake done by Mazda(includes variable valve timing and I think variable intake as well). This should actually be a good motor as the problems with previous Duratec's is that the Bean-Counters had stripped the efficient breathing gear and made them use injection molded intake manifolds w/molded throttle bodies. Since this block is designed for high RPM use (nice short stroke), it never did well in Ford's applications as it was choked on the high end and had the wrong crank/rod/bore geometry to offer any significant low end. The initial numbers for this indicate that it should be a nice rev-happy motor that should match the sporting intentions of this car when mated to a stick. I fear that it will be a poor match for the auto however, which may very well cause many of the main-stream buyers to look elswhere.
[Modified by kar_nut, 4:20 AM 2-8-2002]
See less See more
Re: Mazda 6 Hatchback and Wagon a GO! (kar_nut)
Depends on what auto transmission. If it's a tiptronic and/or is smooth and slick then no problems.
Surely there will be a diesel for JDM and Euro markets, likely a 2.0 though I hope a bigger capacity diesel can be made so they can compete with VW's Passat TDI.
The 2.3L 4 banger should go into Protege's hood with that 165 horses, so that it can fix the power issue people complained.
Yeah but (1) will it fit and (2) how heavy will it be?
2
Re: Mazda 6 Hatchback and Wagon a GO! (David Votoupal)
See less See more
1 - 20 of 25 Posts
