Some of you might remember my thread from a while back, looking for a reliable daily to put a lot of miles on over the next two years. I took your advice, and went a little crazy. I found this one owner 2008 Mazdaspeed 3 with 180,000 miles on it. I spent a little more than I would want to, but the carfax came back clean, it came with both sets of keys, and most of the parts to put it back to stock.
I'm missing the original wheels, so if anyone has a lead on a set, let me know.
First thing I did was remove the stupid aftermarket satellite radio setup that was stuffed in the dash.
I wanted a color other than the silver/beige/black world we live in. It's bright, that's for sure.
It's sitting on a set of Cobb lowering springs and the cheapest KYB struts/shocks money can buy.
Another thing I changed immediately, I replaced the Cobb "hot" air intake with the factory air box (came with the car).
First impressions?
- This is too much power for the FWD chassis. This thing has trouble getting traction in first/second/third.
- The test drive revealed a clunk in the rear. Turns out the rear Cobb sway bar...its mounting brackets sheared off the rear subframe. I have never seen that happen before. I'll replace that with the factory sway bar.
- It has a horrible shake at speeds over 60 mph. The struts are probably no good all around, but I think there might be more at play here. Motor mounts? I think it needs tires as well.
- I think it's consuming a little oil, but I have to drive it more to confirm that. Probably will need a new turbo eventually.
The good?
- No check engine light, airbag light, or TPMS illuminated.
- Interior is really clean.
- Timing chain/water pump were recently replaced.
- I couldn't find anything loose in the suspension other than the rear sway bar.
If it lasts 30k ~ 40k miles I will be happy.
Your thoughts?
First impressions?
The good?
Your thoughts?
