Re: Meguiar's Swirl Remover 2.0 (VW THUNDER)
i have used the original(not 2.0) and it seems to do very little to remove swirls. it hides them for a few days. i understand that this newer formula is supposed to be easier to work with. it is also geared toward machine application, but can be used by hand. you might want to check into the scratch-x instead. also. consider what is causing or is the cause of your swirls. http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
