MFA hidden functions
1344 Views 15 Replies 14 Participants Last post by  SmartAssRacingTeam
3
Does anyone know what these are?
Thanks http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
1 - 16 of 16 Posts
Re: MFA hidden functions (qka2)
Umm. Engine RPM, wheel sensor speeds, cluster check. and i'm not sure what the rest are becuase i hardly ever use them.
someone told me that the gas guage fluctuates when using the digital tach as some sort of air-fuel guage which i think is a big crock of ish.
Re: MFA hidden functions (Maflagulator)
the gas gauge fluctuates because while it's in that mode it becomes super sensitive so it detects the gas sloshing around in the tank.
Re: MFA hidden functions (Madtac44)
SO, HOW DO YOU GET TO THESE FUNCTIONS? MFA IS SO COOL.
See less See more
Quote, originally posted by Madtac44 »
and as if our gauges aren't inaccurate as it is already.
See less See more
Re: MFA hidden functions (Vr6Fidelity)
Quote, originally posted by Vr6Fidelity »
Turn on ignition.
make sure that your odometer is on total and not trip.
with ignition "on", press and hold the odometer reset button (it wont reset becase its on total).
turn ignition to "off" and then back to "on" or start engine if not already running then release the button and pick your easter egg. i think #6 is the digi-tach.
See less See more
Quote, originally posted by Maflagulator »
Turn on ignition.
I think its #7
See less See more
Re: MFA hidden functions (ChadMk3)
OH, YEAH IT WORKS!! SO TRICK.
so can sombody give me a list of what the 9 different function readouts are? all of tem so i can see what im looking at while im being impressed?
2
Re: MFA hidden functions (jamezwhite)
That is so neat, all day it took me a minute to start the car 'cause I was putting it into the RPM mode
and people were looking at me weird
See less See more
you should have just said look at my head getting squashed!!! 3k and you have not heard how to do those... Mee tinks me smell Bull
4
Quote, originally posted by qka2 »
Hahaah Rookie
No jack
See less See more
Re: MFA hidden functions (HELIOS JAZZ)
wow this is freakin awesome i never knew about this stuff...im going to play riiiight now
See less See more
Something else to play with on my car......... as if my stereo wasn't complicated enough, I still haven't figured out how to set the clock on it without the manual.
1 - 16 of 16 Posts
