I am interested in the parameters used in calculating mpg. I believe there are 3, engine load, distance travelled and rpm.
Engine load used to be measured from intake vacuum but after about 91 this changed. My question is how is load now measured? is it from the potentiometer on the maf? I think this must be the case as info from the potentiometer is fed to the ecu and the ecu supplies mpg? However, I have been through the pin out diagram for the ecu and there seems to be no conection to the mfa?
If anyone knows how this all works I would be very interested.
I have a 93 2.0l 16v 9a, owned it for 20 yrs so know it quite well.
Phil
Phil
