1 - 6 of 6 Posts
I recently changed out my charger. I am still breaking the new charger in so I cannot take the car over 3500 rpm. I have a boost gauge but it is not reading anything because the car is not getting up enough revs. I was going to try to verify my gauge to the MFA. the gause only does boost no VAC. The thread that gave the procedue to check the boost through the MFA has been deleted or something. I cannot find it in the searches and the FAQ sticky doesn't work. Do any of you guys still know the procedure to check that in the MFA? Thanks for your help.
too bad it is WRONG!!!!
Turn the MFA selector to #2 position, with ACC on, hold MFA button down, turn off ACC, then back on while still holding the MFA button. The sequence is listed in the bentley. Note, to perform test, your oil temps must be above 80 degrees, can't remember if it is in farenheight or celcius and I can let you know tomorrow if you do not have a bentley
1 - 6 of 6 Posts
